Track Times
Old Apr 1, 2007 | 01:17 PM
LT4hotcam's Avatar
Track Times
What Kind of times should i expect to run at the track with my mods.
They are a Rebuilt LT1 355, with a LT4 hot cam kit, milled heads, K&N air filter for the Ram air, 3.23 gears, A4, on street tires, untuned.
Old Apr 1, 2007 | 05:47 PM
speed_demon24's Avatar
14.0@102
Old Apr 1, 2007 | 05:53 PM
zx1216's Avatar
it should run that stock, you really need an exhaust and headers with a tune to make use of that cam, i'm going to say mid/low 13's
Old Apr 1, 2007 | 06:04 PM
JooneJune's Avatar
13.80s-14.00
Old Apr 1, 2007 | 09:14 PM
96ZCamaro's Avatar
I would think mid to low 13's wouldnt be unreasonable. But as said there are a few things holding you back.
Old Apr 1, 2007 | 09:20 PM
danhr's Avatar
mid 13's at best, probably not even that.
Old Apr 1, 2007 | 09:52 PM
SS RRR's Avatar
Depends on where you are geographically located as well as track/weather conditions. A former member of this board (LeathernecK) ran mid to low 12's @ 108mph w/ hotcam in a '97 at a sealevel track and good air. However that was with a Vig 2800 stall, 3.73 gears and DR's. W/out those three things your times are more than likely going to suffer.
Old Apr 1, 2007 | 09:55 PM
SS RRR's Avatar
Originally Posted by speed_demon24
14.0@102
Have you tuned and ran your newly rejuvenated engine like what?
Old Apr 1, 2007 | 10:05 PM
396D1SS's Avatar
if you have bolt ons such as headers roller rockers etc etc you can go 12's but if you are still on stock manifolds i say mid 13's
Old Apr 1, 2007 | 10:11 PM
His car is stock, untuned, stock stall, and has a hotcam, so it won't me much faster than stock if any.
CamaroRacing12's Avatar
mid 13's if u can drive and hook
Old Apr 1, 2007 | 10:12 PM
I can't translate this sentence, but I should be getting tuned friday-saturday then I'll probably head to the track if its not too hot out.
Old Apr 1, 2007 | 11:47 PM
SS RRR's Avatar
I don't believe anyone has the ability to guarantee ET or trap speeds regardless of what mod list is posted.
Don't be a sissy. It's not that hot yet. So if it's too hot are you going to wait until fall before you go to the track?
Old Apr 1, 2007 | 11:50 PM
lt11997's Avatar
times in sig
Old Apr 2, 2007 | 01:32 AM
I guess mid-high 80's and 100% humidity doesn't count as hot?
