Track Times
Track Times
What Kind of times should i expect to run at the track with my mods.
They are a Rebuilt LT1 355, with a LT4 hot cam kit, milled heads, K&N air filter for the Ram air, 3.23 gears, A4, on street tires, untuned.
Depends on where you are geographically located as well as track/weather conditions. A former member of this board (LeathernecK) ran mid to low 12's @ 108mph w/ hotcam in a '97 at a sealevel track and good air. However that was with a Vig 2800 stall, 3.73 gears and DR's. W/out those three things your times are more than likely going to suffer.
I guess mid-high 80's and 100% humidity doesn't count as hot?
