TR55 or TR6??
From: Austin, TX or Texas State University at San Marcos
TR55 or TR6??
I am doing a bit of a tune up to the LT1.. Its got a new engine with domed higher compression pistons, all forged, heads and cam. I was and AM running the TR55 NGK's and have had no problems but I have heard that the TR6 NGK's are better for higher than stock compression?? My compression is a little over 11:1 now and I think stock is what 10.3:1? Anyways i have a fuel pump on the way, Taylor 8mm wires, and all i need now is to order the plugs... Any imput appreciated. Thanks.
-Chris
-Chris
Re: TR55 or TR6??
The TR6 is one heat range colder than stock. Examine the color of the TR55's (stock heat range); they should be a light grey/tan color for the proper heat range. If they look white, you're running too hot and you want a colder plug. Also the gap is closer on the TR6 (approxiamtely .040"); the TR55's are gapped at .050" which is probably what you want to run.
Re: TR55 or TR6??
I have had the taylors on the car and havent had many problems... Are the MSD's that much better?? Also i was told that I have to get the universal ones that you have to cut to fit... Is that true? I have the AS&M Midlengths on mine... Thanks for the info, i'm gonna stick with the TR55's
Re: TR55 or TR6??
I have the AS&M headers too. The MSD wires get more voltage to the plugs then the Taylors. They also don't make the greatest connection on the opti. We got a deal on the Tayor wire sets, and we have had a few problems with them. The MSD wires was have had the least problems with out of any wire set. You only have to get a universal kit if you are useing a over the valve cover wire loom kit. Checkput Byunspeed.com for prices. He has been the cheepest and don't charge shipping and handling. Good luck with what ever you do. I'm just trying to help with what I been through already.
Re: TR55 or TR6??
I have the over the valve cover setup right now and have had 1 issue. Arcing. Is there any advantage to my setup or should i switch back to regular?
Re: TR55 or TR6??
Originally Posted by Cmr0z28
I've been running the same set of Taylors for 2 years with no issues...
I used them on my motorcycle's for years. I've run all different kinds of wires on all my cars, But I really noticed the MSD's to work the best for me and others.
Re: TR55 or TR6??
