TPS volts with closed blades.....
Old Mar 27, 2004 | 07:58 PM
S.J.S.'s Avatar
Hey guys. My TPS volts with the blades closed is about 1v. Everone says sould be around .2 to .9 and some like it about .5. Will it make a big difference at what I have it at? If so, what kind of difference will I notice? At WOT its 5v.
thanks
Old Mar 27, 2004 | 08:44 PM
Yes, it should be between .2v and .9v for the PCM to recognize it as 0% throttle. Only checking it with a scanner would tell if that was not happening. .5v to .6v seem to be good values.
Old Mar 27, 2004 | 08:48 PM
S.J.S.'s Avatar
Thanks for the 100th time Shoe. I just adjusted it down to .5to .6ish. At WOT its at 4.6v. I wonder if I'll notice a diff.
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
