TPS sensor won't bolt up to 58mm throttlebody?
Old May 16, 2006 | 11:50 AM
flusz28's Avatar
i bought a holley 58mm throttlebody and my stock TPS sensor won't bolt on to the throttle shaft??
Old May 16, 2006 | 01:07 PM
flusz28's Avatar
Re: TPS sensor won't bolt up to 58mm throttlebody?
okay after playing with it i got it to bolt up. which of the three wires do i test to check for the right voltage?
Old May 16, 2006 | 05:16 PM
The blue wire is the signal wire.... read the voltage between blue and black.
Old May 16, 2006 | 05:25 PM
flusz28's Avatar
i adjusted the sensor and all is good. hey what would cause a rocker arm to loosen or back off when the car has been sitting since september? car has 30,000miles on it by the way.
Old May 16, 2006 | 06:36 PM
Dave89IROC's Avatar
if it hasn't been started, its likely normal lifter bleed down, if it has been started(like, today), I would lean towards a collapsed lifter
Old May 16, 2006 | 07:08 PM
flusz28's Avatar
even with such short amount of miles on my car and babing the engine?
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
A's 91 Z28
Jan 11, 2015 10:58 AM
