TPS sensor cause hesitation?
Old Jul 10, 2005 | 09:23 PM
bowtiethunder's Avatar
About a month ago had a radiator hose bust on me. Last weekend I put a brand new GM opti on. This helped alot but still not right. Before the hose busted it ran great. The TPS sensor was right in the line of fire where it busted. Any chance this could be my problem?
Also tonight I checked under the hood for any fireworks. A couple of wires were arcing, but all 8 spark plugs were arcing (not the boots actual plugs).
The Autolite 104 plugs are about 2 1/2 months old. Should I replace the plugs?
Old Jul 10, 2005 | 10:27 PM
CamaroSS30thAnn's Avatar
Re: TPS sensor cause hesitation?
id replace teh arching wires first , a bad TPS would cause a hesitation in accleration the computer would think teh throttle is in lees/more than it actually is
Old Jul 11, 2005 | 09:22 AM
OBE1 95Z28's Avatar
Start with replacing your wires and use dielectric grease on the boots. You might also have the car scanned for knock retard.
KYWes
Jun 14, 2022 06:52 AM
asilomar244
Jul 12, 2015 05:53 AM
SergheiS
Jul 5, 2015 03:27 AM
Nellsw88
May 27, 2015 10:27 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
