TPS Sensor
Old Sep 19, 2004 | 04:13 PM
Joes96z's Avatar
TPS Sensor
Does anyone know the color of the throttle position sensor wire that has the voltage. I am almost dont doing my zex kit and I need to know which wire to tap into. There are 3 wires black blue and white .
help me quick if you can thanks Joe
Old Sep 19, 2004 | 04:51 PM
Re: TPS Sensor
There will be two wires with voltage. You need to specify which one you need. Reference voltage or signal voltage. One of the wires is gray, not white. wiring
FredM
Aug 14, 2015 01:49 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
