TPS help
Old Apr 23, 2004 | 02:11 PM
speedracer93z28's Avatar
TPS help
i just tested my TPS and with the TB closed it read about .25 i want to adjust it to around .65 but i dont know how. i've heard you have to drill a hole? please help. thanks
Old Apr 23, 2004 | 02:59 PM
80TA's Avatar
My tps on my 96 is non adjustable..maybe you can drill out mounting holes so you have some adjustment but can't see why you need to do this.If your tps is shot buy another one..they are pretty cheap..
Old Apr 23, 2004 | 03:05 PM
HBHRacing's Avatar
you will have to "slot" the bolt holes so that you can rotate it while watching voltage
Old Apr 23, 2004 | 03:26 PM
well i tested it again closed=.73 wot=3.64. i dont think that is a good reading for wot, could that low of a reading hurt performance?
Old Apr 23, 2004 | 03:28 PM
wile2k's Avatar
Is the TB opening fully? Pull bellows and watch the TB blades. If you are getting .73 closed then you should get well over 4.0v open.
Old Apr 23, 2004 | 03:32 PM
the tb is really hard to turn, i think it could open a little more, but i need to pull extremely hard. whats the problem this time
Old Apr 23, 2004 | 03:43 PM
Are you testing with cables on or off? IMO, it would actually be better to watch it with a scanner. That will tell you if you are going from 0-100% throttle.
Old Apr 23, 2004 | 03:52 PM
cables are on, how much is a scanner for a 93?
Old Apr 23, 2004 | 04:01 PM
i made the TV cable a little looser and now the TB opens all the way until it hits the stop and i got a 4.10 reading, is that still low?
Old Apr 23, 2004 | 04:06 PM
wile2k's Avatar
Little low but it is ok. Over 4v should be seen as 100% throttle.
Old Apr 24, 2004 | 02:47 AM
Brent94Z's Avatar
Super Moderator
Move your floor mat
Really... about 50% of the time when people are using a scan tool and reporting WOT readings of less than 100% the problem ends up being the floor mat was in the way and preventing the pedal from going all the way to the floor
Old Apr 24, 2004 | 12:23 PM
i think my throttle cable may have stretched over the years i literally have to stand on the pedal to open the TB all the way, i am gonna put some washers on it today to see if it helps.
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
4586
Aug 18, 2015 07:08 AM
