TPS Connector Bad?
Old May 26, 2009 | 07:57 PM
Red97LT1's Avatar
TPS Connector Bad?
Got a P0122 code today so I thought it was my sensor,it apparently wasn't.I hooked up the new sensor and tried to erase the code and it wouldn't let me.I unplugged the connector and the car didn't change idle speeds at all.I jiggled the connector and the car idled down and then back up,and I did it again and the same thing happened.I then got the same P0122 and then a P0123 code.Checked the reference voltage and it was 5.4v.I'm assuming that the connector is bad and I need to return the sensor.What do you think?
HectorM52
Jul 30, 2017 11:46 AM
Nellsw88
May 27, 2015 10:27 PM
edman
Jan 22, 2015 02:45 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
jp2002ls1
Jul 22, 2002 04:18 PM
