Tps ?
Old Oct 6, 2012 | 08:33 PM
Macs95LT1's Avatar
Tps ?
My TPS volts are bouncing back and forth between .062 and .075 constantly. What would cause the TPS voltage to surge? Does while runing and w car off, key in on position. Checked volts going to TPS and it's a steady 5.0. TPS has been changed out 3 times and still have this problem.
Old Oct 8, 2012 | 04:59 AM
RamAir95TA's Avatar
Re: Tps ?
Seems like you have some things backwards.
The 5.0v you're seeing is the reference voltage. 5v is normal.
A clarification on your TPS voltages (blue wire). Are you seeing .062 or .62? If you're seeing .62-.75 then there is nothing wrong. Anything between .23v and .9v is normal.
You may be chasing a problem that doesn't exist.
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
4586
Aug 18, 2015 07:08 AM
