tps!!!
Old Apr 9, 2005 | 12:47 AM
Nick-LT1's Avatar
tps!!!
When you put the tps on does it go just straight on or do you have to twist it on? do you have to line up the inside of the tps with the part the twist witht he tb blades or does it just go straight on??
Old Apr 9, 2005 | 12:38 PM
Re: tps!!!
Generally, after you fit the sensor over the flats on the shaft, you will need to twist the sensor slightly to get the screw holes to line up.
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
4586
Aug 18, 2015 07:08 AM
