TPiS long tubes with true duals...anyone?
Old Feb 11, 2004 | 05:28 PM
FacelessZ's Avatar
I'm about to have my local muffler shop install 2.5" true duals on my car. What mufflers did you go with? I'm assuming the sound won't be THAT different as compared to another set of long tubes, so Bullet, Twister or Borla...plus how long were the mufflers? 12", 18"?
Anyone done true duals with TPiS long tubes? How was the final ground clearance?
Thanks guys!
-Doug
Old Feb 11, 2004 | 05:57 PM
FastWhiteTA's Avatar
Why go w/ 2.5" man, don't waste your time and money, go w/ 3" true duals. Once you do your heads, cam, etc, you'll be wishing you had the 3".
Old Feb 11, 2004 | 06:16 PM
FacelessZ's Avatar
You gotta be pushing a lot more power than is provided with H/C to utilize a 3" true dual...plus I dont want the bad clearance issues that come with it...
If thats what you were planning on doing, you better watch the clearance with having your car already lowered...
Old Feb 11, 2004 | 09:27 PM
I've seen a stock height T/A w/ 3" true duals, he had great ground clearance, wouldn't have any issues when it's lowered. On his BONE stock 01 WS6 (paper filters and stock tires and all) he went from 105 mph to 109 mph in the 1/4 just going to a 3" true dual. After seeing the car, and talking to him, I know he could make it to fit nice. Matt has the same setup in his SS as a true dual, except it's a single 3" pipe dumping before the axle, and he has plenty of ground clearance (and his is lowered almost 2"). Both are better than a 3" catback anyway, so why not go for it, just make sure you get an X pipe, on a street car they're necessary for optimum power out of a true dual.
Old Feb 11, 2004 | 09:32 PM
FacelessZ's Avatar
Interesting...I may just have to do that! So I'm assuming you're going to dump right before the rear axle? So Matt pretty much joined the true dual exhaust into a Y pipe and dumped from there? You say hes fine with his car lowered ~2" with the 3" tubing? Hmm...this may be a good idea...
Old Feb 11, 2004 | 10:00 PM
Yeah dump it before the rear axle. Next time you're thru town come look at his car, and I'll get ahold of my other friend w/ the 3" true duals, you can see the good ground clearance, I'm sure he'll take you for a ride as well, it's damn impressive.
Old Feb 11, 2004 | 10:02 PM
FacelessZ's Avatar
Well then 3" it is! Assuming the ground clearance is as good as you claim...
I'll be dropping it with the Pro-Kit Very soon...found a local guy getting rid of a set for $120..
drptop70ss
May 4, 2015 08:22 PM
cmyname1
Feb 19, 2015 08:38 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Queens94z28
Nov 20, 2014 06:03 PM
Jul 4, 2005 05:00 PM
