totaly confused...
totaly confused...
i've been having a problem with my car..94 camaro lt1 bolt-ons cam,full msd ignition..heres my situation..while back car kept turning off when reaching operating temp. it would start fine,run fine when cold..get it scaned codes are 16,36,42 i changed out the opti harness,icm..still did the samething..so monday i get it towed to a friends, dads shop...he scans it, didnt give me the codes but says the keyless entry reciever is failing..does that sound right to anyone,can that cause my car to just shut off? car turns over every time,when cold..just that now it runs for 4-5 mins and shuts off,wont start back up for a couple minutes.im so freakin lost...worse part, i guess only dealers can do that? since theres programming involved with the key? i dont want to go waste 500-1000 dollars on a part and over priced labor for nothing haha..thanks for anyhelp..all my attention was on the opti, now its the reciever..thoughts?
Replace the coolant temp sensor. It sounds weird but i found several who did this and it fixed problem. Im one of them and 1 year without any issues. Heres one of the posts.
https://www.camaroz28.com/forums/sho...hlight=shutoff
you can bypass the vats system is bad in the ignition switch but without spending a ton of money you can bypass the system with a multi meter and some resistors from an electronics store like radio shack.
FIRST-take your key and measure the resistance in the little chip you will get a number usually in the 4's
SECOND- go to radio shack buy a few different size resistors there cheap like 2-3 buck for like 10 different sizes.
THIRD- take the resistors and add them together until you get the same number and your key.
FOURTH- go under the dash of your F car and look for a tube of wires that is orange that is your vats system wiring follow the wires until you find a 2 wire plug.
FIFTH- seperate the plug and put the resistors into each side of the w prong plug THAT IS ON THE PCM SIDE OF THE PLUG NOT THE KEY SWITCH SIDE.
this will bypass the theft lock system
Not while you are driving, only a few seconds after the engine is started will it kill the engine. VATS has nothing to do with an engine that dies after 4-5 minutes.
no security light, when car dies just the check gages light comes on and rpm needle is bouncing up and down..thanks for your help guys, had the car towed to a different shop..hopefully they can figure somthing out..let you know how that goes..
Originally Posted by shbox.com
If the system detects a fault with the lock cylinder circuit after the engine is already running, the SECURITY lamp will light. The engine will be able to be restarted. This is called “fault enable mode”. (The system saw a good reading from the key at one point during a previous ignition cycle before the failure. So, it considers it a problem and not someone trying to steal the car.) When in fault enable mode, PASSKey protection is disabled until the problem is repaired.
Its possible I had more than 1 thing wrong. I bought this abused Formula a few years ago just to have some fun with it. Same day I bought it i had the dieing problem. I removed an aftermarket alarm system. Didn't help. Installed a new fuel filter, didn't help, changed the fuel pump, didn't help, installed msd coil, didn't help, installed a new opti, didn't help. I needed an extra ignition key so i stopped by a Dealer to have a key made and the parts guy checked my key for the code and told me that my key was defective. He told me they have had many keys go bad that they had replaced. Since getting the new key 3 years ago the car has not died or stalled out. I dunno but thats what happened to me. I have new problems now. Stepson added water to the radiator without bleeding the water lines over heated and cracked both heads, just pulled the motor and tranny today. Time for a complete rebuild has over 110k miles and had water in the oil.
Nobody is right all the time. However, in this case, I am confident with what I have posted.
