THis is total BS, need to get this solved
Old Jul 15, 2003 | 11:17 AM
1994Hawk's Avatar
Thumbs down THis is total BS, need to get this solved
Ok, my car has been running great, unless i drive in rain for about 20 mins, then the car started surging, and ocationally knocking. The car wont accelerate until it hits like 3.5k rpms, then it kicks in and hauls ***, but this is very dangerous, because I have BFG comp T/A's and when the car kicks in, it is near impossible not to spin the tires. People have told me to go to a different opti, but my opti is fine, and im not sure how a different one would help me. Is there anyway i can prevent this from getting wet, is that even the problem??...There has to be someone else with this weird inconvienint problem.
Old Jul 15, 2003 | 11:20 AM
97FormulaWS-6's Avatar
sounds to me like a typical sealed Opti problem...
or unsealed in this case...
Your opti is getting wet.. and thus causing your stumble...
Heck, my car will do the same thing if I don't have it running and wash the engine bay.. until it dries out... the bottom end is a dog.
Old Jul 15, 2003 | 11:29 AM
N20Hawk's Avatar
I had the same problem as you but mine turned out to be because of my Hooker Long tubes were so low that water was fouling the o2 sensors. So not sure if that is your problem but if your o2's are in the stock location I would look at the opti.
Old Jul 15, 2003 | 11:55 AM
94 NO TOP Z's Avatar
Is water getting in your air filter?
Old Jul 15, 2003 | 12:31 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
what kinda cold air do you have? sounds like you are getting water on the MAF(ie, sucking a little into the motor)
Old Jul 15, 2003 | 12:44 PM
N20Hawk's Avatar
Well it looks like he has a 94 firehawk so going off of that he has the SLP Ram air hood, same as mine and the only time I ever got my filter wet is when I misjudged a puddle and the water went over my hood and in the vents.
Old Jul 15, 2003 | 12:45 PM
1994Hawk's Avatar
I have the stock 94 firehawk airbox, its a k & n, and it seals with the hood, but on a 94 firehawk, the ram air holes arent very large at all. But maybe thats a possiblitly, but its pretty hard to get around houston with this problem right now, hence the hurricane, thanks for the help
Old Jul 15, 2003 | 12:47 PM
1994Hawk's Avatar
N20 hawk, i have a white a4 1994 white hawk too, yours is acutally the only other one i have ever seen, same teal graphics too. Do you run the stock ROH wheels when you dont have the draglites on?..they are personally my favorite wheels on hawks.
Old Jul 15, 2003 | 12:49 PM
N20Hawk's Avatar
Actually my ROH's are at a shop right now being powdercoated silver again and I am also in search of a centercap since one of mine flew off. So I am daily driving the draglites.
Old Jul 15, 2003 | 02:06 PM
atljar's Avatar
I had the EXACT problem.
Mine was a combo of a dying fuel pump and dying opti.
Old Jul 15, 2003 | 02:22 PM
Gripenfelter's Avatar
Happened to me with my Hooker LTs.
The O2 sensor wires were getting wet.
I taped them up with electrical tape.
No problems for the last 8 months.
magman
Apr 15, 2016 03:08 AM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
ZXXVIII
Sep 1, 2015 10:13 PM
