Torx head cam retainer and water pump drive bolts...
Old Nov 16, 2006 | 09:17 AM
wrd1972's Avatar
Can these torx headed bolts be replace with strong hex head bolts. I hate torx bolts, I had to crack them loose with vice grips cause I broke two bits.
Old Nov 16, 2006 | 10:37 AM
Sounds like your bits were weak, not the bolts. Yes you can replace them.
Old Nov 16, 2006 | 10:52 AM
Javier97Z28's Avatar
Moderator
Keep in mind the cam gear may not clear the cam retainer bolts if you use something that doesn't fit quite the same. I'd stick with the same type of bolt... the extra mass of the hex head will most likely collide.. especially with a double roller.
Old Nov 16, 2006 | 11:09 AM
Sweetred95ta's Avatar
I used hex head bolts on mine, but like Javier said, you have to make sure that nothing will make contact with them when your timing set is installed and turning.
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
thenewkid
Nov 27, 2014 09:41 AM
