Torsional damper
Torsional damper
Planning a heads and cam build up. I will maintain the stock cast crank. Research has revealed that the LT4 has it's crank rolled and notched to make it more stable in the upper RPMs (redline 6300). My question is: at what point (RPM) does the integrity of the stock crank become questionable?
Would an aftermarket damper make the stock crank more reliable?
Being budget minded, I would like to keep the stock crank and damper. But, better safe than sorry.
Michael
Michael
Michael, I think you should be ok at that rpm level with the stock unit. There seem to be a lot of people spinning higher than that with it. Of course, it never hurts to have better stuff. If everyone could afford it, I am sure they would have forged everything.
