torque strap???
Old Jul 14, 2003 | 05:54 PM
Hawk's Avatar
torque strap???
I just got back from the exhaust shop for a passanger side collector leak that keeps blowin. Anyway, they looked at my car and said that the collector is bangin the frame and is stressing the flange and creating a leak. THey recomended a "torque strap" so that my engine will not torque to the right and bang the headers under load. Anyone have anything like this??? I was told to take this strap, and strap the driver side of the motor down to the frame so the motor won't move. Is this a good idea or should i look at another solution?? Thanks.
Old Jul 15, 2003 | 12:09 AM
Mtrhds94Z's Avatar
Many moons ago we used a length of chain in a similar manner... keep from breaking motor mounts too...
Old Jul 15, 2003 | 01:15 AM
GreenZ28in503's Avatar
Moroso sells solid motor mounts for our cars....anyone have a link?
Old Jul 15, 2003 | 09:22 AM
Toph's Avatar
I don't have a link, but the Moroso part number is #62635. I just bolted a set up on Sunday.
Old Jul 15, 2003 | 09:37 AM
CANTONRACER's Avatar
I just dont see the use of solid motor mounts. Makes for a lot of vibration that is not needed. A chain was popular because only under a load would it work, not idling or low rpm driving, which most do. IMO
Old Jul 15, 2003 | 10:11 AM
Hawk's Avatar
thanks guys. I don't want to use solid mounts, not becuase of vibration, because of the LABOR involved. I'm thinking either to use a strap or chain, or maybe I'll take a piece of solid rubber, and somehow mount it to the frame such that the motor hits that instead of the collector. Thanks for all your replies, it helped a lot.
Old Jul 15, 2003 | 10:25 AM
hairbear21's Avatar
Get some Energy Suspension mounts and you should have that problem.
Old Jul 15, 2003 | 12:33 PM
Hawk's Avatar
http://www.tbyrne.com/lt1catalog.html
under suspension, they have the energy motor mount inserts.
PN 3-1116 and 3-1127.
Is this what u mean?is this a new mount or something else, it says "inserts". Does it raise the motor??? If so that would look like a good idea. Thanks
Old Jul 15, 2003 | 02:47 PM
hairbear21's Avatar
the inserts use the same mount, but you replace the rubber with the poly. If you go to ES's website, I think that they have the entire mount. The entire mount woulb be better because you don't have to take apart the old one.
Old Jul 15, 2003 | 02:58 PM
Mikey97Z's Avatar
I installed the poly mounts (just replaced the rubber part) and it stopped my FLPs from hitting the floor when I accel. I didn't really notice more vibrations, not like when I put in the tranny mount. Just when I punch it everything feels more solid.
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
karpetcm
Aug 14, 2015 03:02 PM
