torque specs for rod bearings ? ft lbs ?
Old Oct 16, 2010 | 08:28 PM
strokerace31558's Avatar
is it 45 lbs for the rod bearings torque specs ? or ? manual says 20lbs then 55 degrees what would that come to ?
Old Oct 16, 2010 | 09:18 PM
brucer's Avatar
you mean rod bolt torque specs? what rod bolts you using?
Old Oct 16, 2010 | 09:29 PM
It doesn't come to anything. It is a different way to tighten them called the torque/angle method. More info about what you are working on might help.
Old Oct 21, 2010 | 09:21 AM
JakeRobb's Avatar
Super Moderator
Just do what the manual says. Anything else would be a mistake.
carl.froehlich
Mar 13, 2015 12:38 AM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
