torque specs for rod bearings ? ft lbs ?
is it 45 lbs for the rod bearings torque specs ? or ? manual says 20lbs then 55 degrees what would that come to ?
It doesn't come to anything. It is a different way to tighten them called the torque/angle method. More info about what you are working on might help.
carguyshu
Jan 22, 2017 11:19 AM
