Torque Specs on headders
Old Nov 18, 2003 | 02:51 PM
Red96Lt1's Avatar
Just like it says, any one know of a torque patern and specs?
Old Nov 18, 2003 | 05:14 PM
Heatmaker's Avatar
Advanced Member
There isn't one..hard to fit wrench in...you can torque some of them if you can get to them. Try 15ft pounds
Old Nov 18, 2003 | 08:34 PM
SVT Killer LV's Avatar
somewhere between tight and really tight
Old Nov 18, 2003 | 08:50 PM
RamAir95TA's Avatar
Proper torque for header bolts are T.A.S.
Tight as sh......
Old Nov 18, 2003 | 09:14 PM
Bud M's Avatar
That's right. Don't overtighten. You only have about 3/8 inch of bolt in aluminum threads. If you are not using Stage 8s recheck them periodically.
No pattern, just tighten them evenly.
Old Nov 18, 2003 | 10:00 PM
ny_z28man's Avatar
Stock exhuast man. torque spec is 30 ft./lbs I dont know if you can use that on an aftermarket gasket and header.
Old Nov 18, 2003 | 10:14 PM
96z's Avatar
96z
I tighten mine as tight as I can by hand using a little 10 mm wrench. No problems yet after 4000 miles.
Old Nov 19, 2003 | 09:38 AM
Red96Lt1's Avatar
Thanks everyone! I will have a copper gasket with stage 8 locking headder bolts. I won't have to worry about stripping out the heads though will I. BTW I got the 1" long bolts and my flange is 3/8" thick.
Novo
Jun 14, 2016 02:58 AM
Bxlt1
Sep 17, 2015 08:31 AM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 09:20 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
