torque converter lockup.. need help bad
Old Dec 5, 2003 | 04:31 PM
SlowAssTA's Avatar
i swapped from an m6 to an A4, had the computer reprogramed, pinned in the big round connector, how does the T/C lock and un lock? is there a seperate wire i gotta run from the pcm to one of the switches on the brake pedal?
Old Dec 5, 2003 | 04:39 PM
My Mighty White 95 Z28's Avatar
Question
The lock up and un lock up is controlled by the PCM. There is no seperate wire that connects to the brake I believe. Are you sure you got a lock up converter? Because they do sell both a lock up and non lock up converter.
Old Dec 5, 2003 | 10:29 PM
SlowAssTA's Avatar
i have a lock up converter, some one told me that i need to run a a wire from the PCM to some sort of momentary switch like the one on the brake pedal...
Old Dec 6, 2003 | 06:40 AM
SlowAssTA's Avatar
ttt
QuickSilver02
Apr 7, 2015 11:12 AM
F550maranello2
Apr 1, 2015 11:10 AM
armedtrigger
Feb 24, 2015 08:30 PM
StansZ28
Feb 19, 2015 07:39 AM
PCLZ28
Parts Wanted
Feb 12, 2015 11:35 PM
