Torque Arm question
Old May 8, 2003 | 10:09 PM
97Camaro007's Avatar
Torque Arm question
The bolt that holds the bushing from the transmission and the torque arm came out.....I was wondering if i could drill a hole through the transmission and put a nut on the other side....or would i hit a pocket in the tranny. Also instead of that do you think that it would hold if I just weld the top of the bushing closed with the torque arm in it....I mean would it hold? Thanks for all comments.
Old May 9, 2003 | 06:15 AM
TTT
Old May 9, 2003 | 06:54 AM
rskrause's Avatar
Moderator
Was it torqued properly, threads in good shape, etc.? In any case, a little blue Loctite will probably solve the problem a lot easier.
Rich Krause
Old May 9, 2003 | 03:50 PM
I used the wrong bolt and the threads got kinda of messed up....i used locktight on the last bolt i put in just in case and it still backed out.....I used the RED locktight also...... I'm going to have to drill and tap i guess or like i said just weld the top.....I don't know what would be the best idea......
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 5, 2015 03:43 PM
Jason Short
Jan 19, 2015 06:34 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
