Is torque arm broken?......
Old Aug 22, 2004 | 11:21 PM
Kurt Crosbie's Avatar
How do I know it is? How do I know if its just the bushing? How can I differentiate between a torque arm mount and a transmission mount being broken? If one is broke, does that generally mean that the other is broken?
Old Aug 22, 2004 | 11:27 PM
OutsiderIROC-Z's Avatar
Re: Is torque arm broken?......
More than likely it is the tranny mount. Mine just broke tonight, again....
Old Aug 23, 2004 | 02:28 AM
BlackBird97's Avatar
TTT I want to know too. What are the symptoms on the car of this? OR a broken tranny mount?
Old Aug 23, 2004 | 05:10 AM
slopokrodrigez's Avatar
Well if you ever remove the torque arm bushing to replace it, you will see why they don't break. The trans mount on the other hand will always break particularly if you are still using the cheap rubber OEM mount. To check it, push up on the transmission tail shaft and look at the rubber pad it sits on. You will see it develope a large gap in the middle of the rubber. It can cause a thumping sound when first taking off from standing still. Best to replace it with a Eurothane mount. For that matter, it's a good idea to replace all the rubber bushings in the suspension with Eurothane.
Dave
Old Aug 23, 2004 | 11:40 AM
urethane
Old Aug 23, 2004 | 12:13 PM
tomatocity's Avatar
Dave
don't the urethane mounts increase the driveline noise? ie: you can hear it inside the car.
Old Aug 23, 2004 | 03:23 PM
Dave C. '97 Z28's Avatar
You can.....like......get under there and look.
-Dave C. '97 Z28
Old Aug 23, 2004 | 09:22 PM
1racerdude's Avatar
-Dave C. '97 Z28
DITTO:nothing like two good eye ball's on the job.
Old Aug 23, 2004 | 10:30 PM
tomatocity's Avatar
Kurt here is a photo (courtesy of shoebox) of the three types of transmission mounts. The bottom part is metal and if you were turn it 90 degrees you would see two bolt holes, one on each side. I was looking for a photo showing the mount in the car but was unsuccessful. I might change mine tomorrow night and will take photo's when I do. I will send the photo's to shoebox, if he would like, and he can add them to his excellent resource webpage.
I will start the rumor "shoebox for Man of the Year".
Old Aug 23, 2004 | 10:58 PM
1racerdude's Avatar
I'll second that motion.
Old Aug 24, 2004 | 12:32 AM
Bud M's Avatar
-Dave C. '97 Z28
Old Aug 24, 2004 | 03:23 AM
TobyZ28's Avatar
Yes. Thats why we get a louder exhausts though
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
realistyc
Jul 28, 2015 07:32 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
Fastbird93
Jul 11, 2015 04:37 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
