Top Speed Limiter?
Old Mar 31, 2004 | 09:19 PM
95_Blk_Z28's Avatar
Top Speed Limiter?
I was wondering what the top speed limiter is and how it works exactly, and what happens if you eliminate it?
Also I was wondering if you descreen a MAF will you still pass Emmisions?
Old Mar 31, 2004 | 09:26 PM
rskrause's Avatar
Moderator
Re: Top Speed Limiter?
It's like the rev limiter. When the programmed speed is reached it cuts fuel until the speed drops (I think it needs to drop ~10mph below the speed at which the limiter is activated). The PCM can be reprogrammed to change or eliminate the limiter.
Do a search on descreening the MAF. I doubt any gain but it shouldn't have anything to do with passing emissions.
Rich Krause
Magenta_Hearts
Mar 22, 2015 03:36 PM
canbaufo
Feb 24, 2015 10:27 AM
grabbem88
Feb 10, 2015 06:20 PM
NewsBot
Jan 11, 2015 06:10 PM
mark0006
Dec 25, 2014 09:50 PM
