Top head bolts question
Old May 6, 2006 | 01:03 PM
Jeff95TA's Avatar
I'm putting the heads on my new short block and have a quesiton about the thread sealer. ARP directions say to only use the thread sealer on the bolts going into the water jacket, not on blind holes. The top four head bolt holes are blind holes BUT several of them have a small hole in them. Would these go into a water passage (I think) or an oil passage? Is it okay that there are holes? Just put some thread sealer on those ones too?
Old May 6, 2006 | 01:11 PM
arcticz28the383's Avatar
Re: Top head bolts question
I might be mistake but don't all the bolts come with thread sealer on them from the factory?
Old May 6, 2006 | 01:13 PM
Jeff95TA's Avatar
They might, and I know you can buy precoated ones. But I'm questioning whether it's okay for the blind holes to have a hole in the bottom of them and if using sealer will take care of any issues.
Old May 6, 2006 | 01:35 PM
Jeff95TA's Avatar
Never mind. Did a little more searching and found that it's possible for those holes to be drilled a little too deep and break into the coolant passage. Thread sealer on them should do the trick.
Old May 6, 2006 | 07:49 PM
firebirdStud's Avatar
from the factory yes they come with sealant on the bolts. Put it on all of them so you don't have to take it apart later.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
ChrisFrez
Dec 7, 2014 06:01 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
