top end upgrade
Old Jul 18, 2008 | 02:29 PM
pologreenZ's Avatar
top end upgrade
I want to upgrade my top end with a edlebrock lt1 intake manifold was wondering witch heads to go with trick flow or edlebrock the trick flow are 195 cfm intake runners also would the trick flow port match or would i have to get them ported a little also witch would work better with a hot cam kit
Old Jul 18, 2008 | 03:02 PM
96capricemgr's Avatar
You are making a pretty big and poor assumption in thinking the Edelbrock parts are any good. The Trickflows would result in a compression drop which is the wrong way to go.
Buying the HOT cam "kit with either would be silly since it would include weaker springs than either head is supplied with, and the rockers wont allow you to use a real cam when you realize what a mistake the HOT cam was.
I know it is not what you want to hear, and I also know I offend folks easily but fact of the matter is every idea you put forth is a bad one.
The Edelbrock full package is rated less at the flwheel than a good heads and cam setup based on ported stock heads will give you at the tires.
www.advancedinduction.com is my choice they offer more power and better reliability that other alternatives at barely any more cost. The times in my sig are with an obsolete package from them.
On a M6 stock shortblock Camaro I know they have delivered as much as 429rwhp the Edelbrock full kit is rated at only 396 at the flywheel, big difference there.
Old Jul 18, 2008 | 03:14 PM
pologreenZ's Avatar
port
so your saying that i sould port the heads and intake as well as rebuild the heads with better springs valves and so on , bigger tb as well
ps
im not a mechanic so sugustions are helpful
Old Jul 18, 2008 | 03:32 PM
seawolf06's Avatar
ps
Yes. Take what you have and send it to AI to have them port and polish and they will sell you a cam to match. That way everything works together.
Although, there is no guarantee that your bottom end will hold up with the increased power.
Old Jul 18, 2008 | 03:53 PM
83tpi_3rd-gen(sri)'s Avatar
not wanting to start another debate but dont forget about Lloyd Elliot.guy does great work for a great price and will answer any questions you have.
http://www.elliottsportworks.com/
check it out,just another option
Old Jul 18, 2008 | 04:10 PM
Joe B's Avatar
Yea, these guys are 100% right....The edelbrock intake yields ZERO power advantage over the stock LT1 intake......and your much better off retaining your stock LT1 heads and having them done by either advanced induction or Lloyd Elliott.......The stock trickflow heads, the stock Edelbrock heads, and the stock LT4 heads will ALL leave you well under (power wise) what a AI or LE package will give you (quite a bit cheaper as well)................Joe
Victor Lamb
Aug 26, 2017 02:52 PM
Collector Car
Jan 5, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
