Took off hub...did i mess this up?
Old Mar 9, 2004 | 08:09 PM
JJ's95B4C's Avatar
I was able to take off the hub today, but the only way to crank the puller and not have the crank go in circles was to wedge a screw driver in the flywheel. I put it in a hole on the flywheel and let the screwdriver press against the block where the starter goes. Did i mess anything up here by doing that? Thanks.
Old Mar 9, 2004 | 08:25 PM
gb95zconv's Avatar
No...you should be fine.
Old Mar 9, 2004 | 08:39 PM
JJ's95B4C's Avatar
I'm probably going to do the same to screw the hub back on, so i want to make sure that nothing bad will happen.
Old Mar 9, 2004 | 08:50 PM
ibanez6rg's Avatar
I used a breaker bar wedged between 2 bolts on the hub and kept force downward on it. Worked great.
Old Mar 9, 2004 | 09:13 PM
lt1g3n's Avatar
i did the same thing kinda, only i stuck a bar with rubber coating in the flywheel .
Worked well, and did no damage, its ok.
Rittmeister
Aug 7, 2015 01:13 AM
88IROC_Z
Jul 22, 2015 11:38 PM
Boss002
Jul 9, 2015 03:33 PM
2QUIK6
Jul 2, 2015 07:02 AM
