Took the camaro out for its first good run!
Old Aug 14, 2005 | 11:57 PM
Silvershark's Avatar
I took the car out today with my buddy who owns a 440rwhp 509tq trans am. He said my car defiantly felt strong and I should be right around 400rwhp. We then went in his monster and he showed me what his car can do. WoW! With 430 gears and a supercharger the power is immediate! His car is just amazing to say the least. I cant wait to get some more miles on my car and throw a 100 shot on top of my setup. I am hoping for 11's. Unfortunantly the person who dyno's up here is no longer doing it due to legal issues. So I dont think I will be able to dyno my car and see where its at.
However I am hoping 500rwhp isnt too much out of my reach with a 100 shot.
I got all the little bugs worked out minus a weird stumble at 5k in 3rd gear. I will check the fuel pressure tomorrow and see if that is the problem, if not I may be changing my optispark out for a better setup.
Old Aug 14, 2005 | 11:59 PM
Bow94z's Avatar
Re: Took the camaro out for its first good run!
what setup are you running?
Old Aug 15, 2005 | 01:31 AM
GM847/LE2 on a forged 355 with all the boltons and electric water pump etc. Cant go any bigger unless I went with a 383.
Old Aug 15, 2005 | 11:18 AM
limige's Avatar
you should pull 12's at least n/a, with a 100 shot low 11's? i know if you hit it with a 150 you should be able to dip 10's.
Old Aug 15, 2005 | 12:16 PM
89385formula's Avatar
Depending on your suspension setup, car weight, traction etc..you should really be in the 11's now if you ask me. With a 100-150 shot 10's shouldn't be a problem, although there are alot of variables to that.
kyle
Old Aug 15, 2005 | 07:03 PM
new_z's Avatar
Thumbs up Re: Took the camaro out for its first good run!
who did your motor? your car sounds bad a$$! good luck with those times. youre wayyy ahead of me!
Old Aug 15, 2005 | 10:23 PM
Yah, I need some slicks on and to put my 9" in. Then I should be in the 11's for sure.
I will try and make it to the track this weekend and see what I do for MPH through the quarter.
Old Aug 15, 2005 | 11:05 PM
Jameslt1TA's Avatar
Ya 11s na should be possible...do some weight reduction and get traction and you'll be there. Sprayin to a 10 would be cool too.
Good Luck
oldschool
Feb 9, 2016 09:21 PM
Feffman
Oct 9, 2015 05:42 AM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
