Too much spring for a cam?
Old May 17, 2004 | 08:24 PM
Xride's Avatar
Can you have to large of springs for a cam?
like would you lose power by using a really strong spring if your cam doesn need it?
Old May 17, 2004 | 08:54 PM
Red_94Formula's Avatar
Yes some will be lost but not much. How close of a gap is there?
Old May 18, 2004 | 01:06 PM
Xride's Avatar
I mean like using the crane dual springs for the stock cam with 1.6 RR's
Old May 26, 2004 | 10:51 AM
Xride's Avatar
anyone?
Old May 26, 2004 | 11:17 AM
95_LT1_6SPD's Avatar
I dont know/ever heard of any problems with too much spring. You will loose out on some power, as a stiffer spring is harder to compress, but how much is questionable.
Old May 26, 2004 | 11:41 AM
Xride's Avatar
ok, I was jsut worried that maybe it would break something or I dont even know.
I have chromemoly pushrods so they shouldnt bend or anything.
Hope I dont loose too much from it
and I hope its not too much of a pain in the *** to change the springs while the heads are on the car.
Old May 26, 2004 | 03:19 PM
Mindgame's Avatar
Power lost from strong valvesprings is "0". For every spring exerting pressure on the opening ramp, there is one exerting near equal pressure on a closing ramp. It is a regenerative system.
A hydraulic cam can take some high spring pressures. You have to watch oil viscosity and pressure though, cause these two can cause some pump-up problems. Generally, a strong spring only helps things but too much spring can also increase cam and lifter wear. "Too much" is a relative word though. How much open and closed pressure are you talking here?
-Mindgame
Old May 26, 2004 | 03:22 PM
Xride's Avatar
-Mindgame
I dont know how much pressure, how can I find out?
they are the crane dual springs, pn 99893-16
Old May 26, 2004 | 04:12 PM
Mindgame's Avatar
Alrighty then, I can probably get you an answer with a little homework (not familiar with that spring) but have you thought about calling Crane and talking with them?
I'll get back with you....
-Mindgame
Old May 26, 2004 | 04:15 PM
Xride's Avatar
-Mindgame
no, but thats a good idea.
I'm going to call right now.
this is what I found on the site
http://www.cranecams.com/?show=brows...rtNumber=99893
Outer Diameter Outer 1.460
Outer Diameter Inner 1.075
Inner Diameter Inner .803
Damper NO
Seat Pressure @ Installed Height 120# @ 1.875
Open Pressure and Height 394# @ 1.175
Coil Bind 1.080
Average Spring Rate 391 #/IN
Old May 26, 2004 | 04:21 PM
Valkyn71's Avatar
If your running alot of pressure your stock lifters could collapse, seems unlikely tho.
QuickSilver02
Apr 7, 2015 11:12 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
grabbem88
Feb 22, 2015 11:16 AM
