Is this too much lift for a stroker?
Old Jan 25, 2004 | 01:19 PM
BottleFedZ28's Avatar
As some of you know I'm building a 383.
For the cam I have an XE230/236.
I was going to get 1.7s but I just learned I could even go with 1.8s and still have .100 of clearance for piston to valve.
Any kind of problems I could run into with .612/ .630 lift?
Obviously I will have to go with shorter pushrods to correct the valvetrain geometry.
Any other down sides?
Old Jan 25, 2004 | 01:44 PM
slopokrodrigez's Avatar
Downside would be no vacuum for accessories. Rough idle and probably surging. It may also have a clearance issue with connecting rods. Not sure, haven't seen that problem but heard it's an issue with large lift cams and stroker cranks.
Incidentally, your push rods will more than likely get longer not shorter since larger cams have a smaller base circle so that they can fit through the same bearings. I find very often they stay the same length. Check them first before buying them.
Old Jan 25, 2004 | 08:48 PM
philcam01's Avatar
I have the same xe cam in my car running 1.6rr's and I have surging problems in 5 and 6 gear just riding around town, but on the + side of that the car flat out hauls some A-- . Now as far as clearance goes you will have to clearance the rods for that cam and then get the rods rebalanced, I also had to clearance the block alot !!!!!!
good luck with your project
Old Jan 25, 2004 | 09:55 PM
N2OpwrdTA's Avatar
Sorry I couldnt resist to ask....are you two also members of the "380rwhp Stroker LT1" crew? I dont understand why you guys run such small cams in such large cubic inch engines. Hell, the 350ci engines even like cams like the gm847, cc306, xe233/239+ etc.
Edit....on the topic note. Damn, thats a lot of lift. I guess as long as you got tall valve covers, good springs, etc....that youll be fine. Just make sure you dont skimp on any of the necessary parts.
Maybe you should run some thick *** head gaskets also to prevent the valves from smacking into the pistons ...but then there goes your optimum quench height/distance.
Old Jan 25, 2004 | 10:20 PM
Tony Danza's Avatar
excuse my ignorance.
But exactly is surgging and what causes it?
Old Jan 25, 2004 | 11:10 PM
I have .150 of clearance with the XE 230/236 and 1.6 rockers.
Do you have a stroker? What cam do you run? How streetable is your car?
Old Jan 25, 2004 | 11:33 PM
jonaddis84's Avatar
I wouldnt. I dont see the need. There was a reason that cam was made with that lift, more lift doesnt always = more power. You need to speak with a knowledgeable engine builder or a cam grinder, or even a head guy, you will most likely cause so much turbulence in there that you will actually hurt performance, but I could be wrong, not to mention how unstable the valvetrain will be unless going with shaft mounts.
Dont take it all from me though, post in advanced or speak with an expert.
Edit, just noticed you were the one posting about shaft mounts, so throw out unstablility, but you are still looking at large amounts of unwanted turbulence, so speak with someone like Compcams, LLoyd eliot would be an excellent guy to talk to as well
Old Jan 25, 2004 | 11:43 PM
N2OpwrdTA's Avatar
Red face
Its all in my profile there killer
Old Jan 25, 2004 | 11:50 PM
I think you would need to look at your head flow sheet to see if you need that kind of lift. If the heads continue to increase in flow to 0.650 and higher, the extra lift will generate more power. If the flow stalls as .550-.600, you aren't going to see much of anything in the way of flow increase.
RUENUF
Mar 13, 2016 03:37 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
