too high mileage?
Old Sep 29, 2004 | 10:28 PM
mojorisin's Avatar
too high mileage?
i have 175k miles on a '94 z28. is this too many miles to put a cam such as the cc306 in? if not, what all would i need to change?
Old Sep 29, 2004 | 10:57 PM
Valkyn71's Avatar
Re: too high mileage?
I wouldnt do it if you cant afford to rebuild the engine when it goes out.
You would need cam, pushrods, and springs at bare minimum.
Preferably lifters, rockers, and timing set also. Not to mention headers, CAI, ect that are needed to support a cam'd engine.
Old Sep 29, 2004 | 11:05 PM
mojorisin's Avatar
im soon to have long tubes, and i have the rest of the stuff to support the cam, and was planning on getting all the valvetrain components. i was just asking as far as seals needing to be replaced, or things that could possibly break. i was also planning on replacing the timing chain
Old Sep 29, 2004 | 11:15 PM
Valkyn71's Avatar
You just need the timing cover gasket set, and the intake gaskets.
Can be purchased all together Here
Might be a good time to replace your waterpump and opti if they are old also.
Old Sep 29, 2004 | 11:20 PM
BlackLT1_TX's Avatar
commonly engines with your mileage will not take well to spinning up to the rpms that a cam that large likes. (ie 6200-6600rpm) i wont tell you that if you do it, that you will for sure have this problem though, because under the best circumstances it all works out, with that said, i would go through the bottom end and replace the main, rod, cam bearings, and have a new set of rings, hone, and putting it back together. thats what i am doing just because of the countless horor stories of guys not making it out of their breakin period before spinning some bearing. just a heads up, you should at least make sure the oiling system is up to par and that your cam bearings look alright before you slid the new cam in.
good luck,
james
Old Sep 29, 2004 | 11:22 PM
mojorisin's Avatar
so when people say it's not a good idea, are these the things they think are going to go out due to the cam? b/c i have a brand new everything, just an old rotating assembly and block
Old Sep 29, 2004 | 11:25 PM
if you have a new set of bearings, rings, etc. etc. then i'd say you dont have anything to worry about (unless your considering the transmission and rear end, then theres anther story )
Old Sep 30, 2004 | 01:56 AM
Spinner's Avatar
New power on old parts changes wear patterns and causes bearings to do the nasty.
ad356
Apr 11, 2015 08:49 AM
HectorM52
Jan 30, 2015 11:08 PM
Jason Short
Jan 19, 2015 06:34 PM
Dec 1, 2014 08:08 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
