Intake gasket plastic keepers
Old Jul 12, 2005 | 07:33 AM
tim95z28's Avatar
The 4 little plastic keepers that hold the gasket in place, are you supposed to leave them on, or are they just to position the gasket, and to be removed before mounting the intake manifold?
thanks!
Old Jul 12, 2005 | 07:44 AM
Re: Intake gasket plastic keepers
No need to remove them. They will crush with the gasket.
Old Jul 12, 2005 | 08:01 AM
tim95z28's Avatar
thanks!
Old Jul 12, 2005 | 08:07 AM
Jameslt1TA's Avatar
I removed mine, but just because they didn't line up the gasket correctly. They are kind of nice if the work correctly. To hold the gasket if you can use them, i would just run your silicon for the front and rear and then put the gaskests on, holds them down good.
Old Mar 16, 2007 | 07:08 PM
lt1s10blazer's Avatar
what do u do if the keeper falls into one of the round oil drain holes in the lifter valley??????????????????????????
Old Mar 16, 2007 | 07:11 PM
mdacton's Avatar
I don't see that little jank hurting anything
dfarr67
Apr 10, 2015 07:44 PM
rjc1629
Jan 27, 2015 10:46 AM
Cam's maro
Jan 8, 2015 05:01 AM
thenewkid
Nov 27, 2014 09:41 AM
