Toluene Octane Booster!
Old Feb 25, 2003 | 09:48 PM
  #16
Dr.Mudge's Avatar
Originally posted by Loadre
Isn't toulene a carcinogen(sp?)
I believe they all are, but a 1680 HP GN guy told me Xylene is worse.
Old Feb 25, 2003 | 10:01 PM
  #17
CJ's Avatar
CJ
Originally posted by Kraest
Xylene will start gnawing away at your plastic fuel lines... you might want to throw a few oz of Marvel's Mystery oil into the batch, while you're at it.
Mike
Probably if you use it in a high concentration or mix it all the time, but I dont think mixing a gallon here or there with your gas when you go to the track will hurt anything. Ive been doing this for about 2 years now with no problems. But I guess its not that hard to throw in a couple of oz of oil just to be safe.
Old Feb 25, 2003 | 10:05 PM
  #18
buelldevil's Avatar
Both are carcinagines, it is the benzene in them that is the biggest worry. But you get overexsposed to it when your pumping your gas, so why worry!
Old Feb 26, 2003 | 11:02 AM
  #19
Wild1's Avatar
Found Shermin Williams with Toluene at $8.50/Gal. Thanks... I'll go that route.
By the way, what type of oil are you suggesting to add? I read in one of the mix web pages to add a few ounces of ATF as a lubricant. Seems to me that would make a lot of smoke.
Old Feb 26, 2003 | 11:17 AM
  #20
TedH's Avatar
If this is going in the '95 I don't know why you would even need more octane than regular pumop gas unless something is wrong...
Why not just get some Motorsport 103 unleaded at the track for $1.25/gallon and be done with it? Any more octane than is needed to prevent knock is a waste of money and actually slows you down.
Old Feb 26, 2003 | 07:04 PM
  #21
Wild1's Avatar
Two reasons for the octane booster....
1) I've got knock at 4000-6000 RPM and I want to verify it is or isn't false knock. If it goes away, then it is real knock.
2) I race in the Nevada Silver State Challenge Events which requires good octane to reduce detonation with 128*F Temps for 90+ miles. That car has a 32 Gallon Steel Fuel Cell so it will need quantity when it comes to octane boosting... 11:1 compression on Iron heads.
Thanks guys... I'm off to Sherwin Williams after work tonight.
Old Feb 26, 2003 | 10:48 PM
  #22
Dr.Mudge's Avatar
I've always wanted to know if either of these burns cleaner than straight gasoline, but never was able to find an answer.
Old Feb 27, 2003 | 02:07 AM
  #23
Pro Built Automatics's Avatar
Xylene, toluene, benzene are all good at slowing down the burning process of gasoline, while retaining high BTU's. At what mixture of these you would need would require some research. Adding oil kills the increase in octane. It's hard to believe that I used to get toluene for $.50 a gallon in the very early 70's.
Aug 24, 2015 06:41 AM
dkred94z
Aug 20, 2015 03:09 PM
tnmotown
Aug 10, 2015 11:52 PM
whitehooptie
Jul 12, 2015 06:10 PM
asianice25
Sep 16, 2002 02:32 PM
