TN227XR cam vs CC503
Old Mar 29, 2007 | 01:17 PM
rasputin's Avatar
A friend of mine wants to put a cam in his LT1 where he can run mid 12's with the right tires on his M6, he has all the bolt on's, and plans on putting 1.6's and the correct spring package in there to keep it in spec. I recommended going custom, but he has a tight budget and would like to stick to something off the shelf. I said fair enough if you cannot pay for it, then I recommended the cc503 because it seems to be a pretty good daily driver for what he wants. Then he came across this cam from combination motor sports:
Comp Cams TN227XR Camshaft 227/233 duration @ .050", .560"/.569" lift with 1.6 rockers, 111lsa. Huge top end pull N/A cam, 3000+ stall converter recommended for auto cars. THE cam for street/strip cars looking for maximum power without sacrificing too much driveability.
Another friend of mine had good luck with this cam but I was wondering if anyone else had experience with it, especially for a daily driver.
Old Mar 29, 2007 | 01:34 PM
buzz12586's Avatar
The cc503 would go mid 12's on some drag radials in an M6. Don't know much about the 227 but I do know the cc503 has great driveablilty.
parkers Z28
Mar 11, 2016 08:14 PM
nikolt1
Feb 27, 2015 09:10 PM
camy 1993
Feb 1, 2015 07:16 PM
InfernalVortex
Jan 17, 2015 09:35 AM
