tires - bigger on the rears?
Old Aug 17, 2003 | 01:18 PM
sabre81's Avatar
my 94 z has 255's on the rears and 245's on the fronts with stock rims. Is this normal? should i just go with all 245's all around with my new tires?
thanks
Old Aug 17, 2003 | 01:25 PM
AsianSensation's Avatar
245/50/16 is normal. I perfer to have the tire size all the same for rotating reasons.
Old Aug 17, 2003 | 01:26 PM
Jay-Roll's Avatar
In my opinion you can just go with 245's all the way around. That's the size they all come stock. That way you can rotate the tires if need be. Ya know just in case the rear ones get a little worn down for some reason. Also I don't think the added width of 255's will even make a difference in traction, probably not even noticable.
Old Aug 17, 2003 | 01:45 PM
TedH's Avatar
There is nothing wrong with having slightly wider tires on the rear. Depending on how you use your car it may be a slight advantage or it may nbe of no consequence. The amount of difference is so minimal it wouldn't matter even if you did rotate them. I have 28 x 12.5 x 15 on the back and 28 x 7 1/2 x 15 on the front.
Old Aug 18, 2003 | 08:47 PM
Jay-Roll's Avatar
I'm not saying added width wouldn't give you a traction advantage. But the minimal width of 245's to 255's probably isn't even worth the added price of the tire or probably even a noticable traction increase. Just my opinion.
Old Aug 18, 2003 | 09:05 PM
revtime's Avatar
It won,t hurt ya.
Just for the record I have 275/50/15s on the rear and 165/15s on the front.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
carguy0119
Apr 11, 2016 11:11 PM
HarleyZ28
Oct 5, 2015 06:23 AM
QuickSilver02
Apr 7, 2015 11:12 AM
