Tired Valve springs robbing HP?
I've been watching on Nascar tech how they keep talking about the valve train with the one engine rule and they keep changing are the springs to keep the HP up. Sounds right for an engine running in the 9k range.
Question is with 85k on the clock, one track visit and driven like a NORMAL car what is the potential loss??
I do have 1.6 golds on a stock cam for now and future plans call for a heads/cam but six mos away. Can it wait or will the difference in HP be worth the work now?
Lastly there was a page I saw a while back that showed how to remove the springs, with tools needed as well as how to rotate the crank so that every piston is on top starting with TDC.
Thx
Thx
Not sure if you"ll pick up any HP, I didn't, but I had valve float around 5500 RPMs and droped in a set of GMPP 1.6 rockers and a set of LT4 springs and it fixed it right up. Didn't pick up any tie at the track, but no more valve float
Originally posted by cocheese
I don't mean to sound stupid or anything, but how do you tell if you have valve float?
The truth is my car doesn't see WOT maybe once a month if that. Its not that I don't like the WOT feeling there is just very few times that I'm not in traffic or without my daughter. Besides damn gas is now 1.90- 2.00 range here.
Point is yeah I wouldn't notice flave float. Can it be done with the car at idle with out a load? in other words rev it to 5k to listen for float?
What spring compresser should I get? I am set on the LT4s till I get the cam.
Thx
Thx
Thx
Thx
