Tip for stuck ground cable?
Old Aug 8, 2014 | 01:13 PM
  #16
raroz28's Avatar
Re: Tip for stuck ground cable?
Can anybody confirm whether the small black and white wire from the PCM to the block can cause a slow crank when warm? That is one ground that I did not clean up. I'm wondering if this could be a culprit.
Old Aug 14, 2014 | 03:28 PM
  #17
nikko's Avatar
as far as ground cables go I just bought a 1996 z 28 and looking around in engine compartment I found a ground cable on the drivers fender that was just hanging any idea what it was supposed to be grounded to thanks richard
Old Aug 14, 2014 | 04:03 PM
  #18
timnfxr's Avatar
If its the braided ground strap, it is bolted to the subframe. The other end is connected to the stud the holds the coil/ICM to the head. Is this the ground you referring to?
Old Aug 14, 2014 | 10:25 PM
  #19
Don't think so. There are folks that have mistakenly left this disconnected before.
Old Aug 15, 2014 | 08:49 AM
  #20
raroz28's Avatar
Then I imagine my battery is no good from the years of driving with the old alternator. It was only putting out 13 volts and anytime I get that battery tested it just barely passes - CCA's are well below what's on the battery label.
Old Aug 15, 2014 | 12:46 PM
  #21
nikko's Avatar
thanks timnfxer That is the cable Now as soon as the car cools down I'll get in there and put it where it's supposed to be Richard
HibachiZ28
Nov 6, 2015 12:53 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Aug 24, 2015 06:41 AM
detroitmuscle
Jul 31, 2015 04:21 AM
pimpen1024
Jul 8, 2015 09:08 PM
