Tip for bending dipstick tubes etc.
Old Dec 3, 2006 | 11:42 AM
JP95ZM6's Avatar
When bending a metal tube, kinking it is frequently a problem. I see this mentioned over and over regarding dipstick tubes in header install write-ups. To prevent the tube from kinking, tape off one end, then fill the tube with sand, tamped in really well. Tape the other end. Now you can bend the tube at will, and the sand will keep it from kinking. I use this for all kinds of tubing, up to an inch or more with heat added. Don't bend the same spot too many times without heating it. For tough jobs, get the part red hot first to take out any heat-treat. Don't quench it in water, just let it cool slowly, so it's nice and soft. You can always do a water or oil quench later if you want to re-harden the part.
To make sure no sand remains afterwards, I pre-clean the part real well, and when I'm done I take it to the quarter car wash and blast the heck out of the inside. Then inspect the inside with a bendy light. On a dipstick tube, especially focus on the little raised bead where it seats to the engine block. Obviously, putting sand in any car part requires EXTREME care to not leave one grain behind.
Old Dec 3, 2006 | 12:45 PM
pHEnomIC's Avatar
Pretty handy trick, thanks for sharing, I am sure i can use this someday.
HectorM52
Jul 30, 2017 11:46 AM
Jun 6, 2015 08:27 AM
jmadoll
May 27, 2015 07:13 PM
May 15, 2015 10:43 AM
jmadoll
Mar 3, 2015 10:16 AM
