Which timnig set for a 93 Lt1?
Old Jul 16, 2006 | 02:58 PM
user 647483's Avatar
Which timing set for a 93 Lt1?
I have a 93 Firehawk (A4 LT1) and we're almost finished with the LE2.1HL install.
The cam comes up -9* or +6* with the stock chain.
The stock chain really needs replacing anyhow (~35,000)
I probably should have thought about this earlier
Anyhow, can anyone direct me to the correct timing chain or timing set
I need to make this work at least close to 0*?
I do have an EWP if that helps any.
I think someone suggested the Hex-Adjust set from Coyles at one point.
Please tell me I don't have to convert to a 95+ opti and timing cover.
Old Jul 16, 2006 | 03:02 PM
joshp007's Avatar
Re: Which timnig set for a 93 Lt1?
I used a similar setup and I used the Hex adjust set Worked great for me
joshp007's Avatar
Let us know man
Old Jul 16, 2006 | 06:51 PM
Appears to fit a 93, but not adjustable
http://store.summitracing.com/partde...0&autoview=sku
There's got to be a 3-way one here somewhere.
Old Jul 16, 2006 | 09:00 PM
Will these work?
http://store.summitracing.com/partde...5&autoview=sku
Old Jul 16, 2006 | 11:37 PM
You do know that if you use an adjustable cam gear, you will need to make timing adjustments in the programming to compensate, right?
Old Jul 17, 2006 | 05:49 AM
That's not a problem, I can do all the tuning I need.
I'm just at a complete loss as to what part(s) I need.
DirtyDaveW
Dec 1, 2016 05:37 PM
Roadie
Feb 16, 2015 10:34 AM
chuyz28
Jan 15, 2015 04:14 PM
