timing set off one tooth!!!!
Old Apr 16, 2004 | 06:54 PM
Quick96Z's Avatar
Angry timing set off one tooth!!!!
AHHH!!!! I'm 99% sure my timing set is off a tooth. Do me a favor and give me some of the usual symptoms or this annoying problem. My car starts, and seems like it idles ok (i have a 230/236 so it's hard to tell).. When i get moving it has zero hp. It kinda bucks a little bit when i'm rolling, and it back fires like crazy when i let off the gas.
I know you guys have been here and done that, so let me know what your problems were....thanks guys
trav
By the way, i figured out that hanging RPM prolbem...it was the idle set screw.
Old Apr 16, 2004 | 08:30 PM
smoknta's Avatar
sounds like you have a couple of plug wires swapped. I know it sounds stupid or to easy, but this happed to a buddy of mine. He did a hotcam swap and ported his heads. He put the motor back in and it ran fine for the first 5 to 10 min. then it just started to back fire like crazy. You give it some gas and it got worse. Turned out two of the plug wires were swapped. I actually could not believe it ran that well with two wires swapped.
Old Apr 16, 2004 | 08:33 PM
formula2fast's Avatar
Lt1 timing is not adjustable nor is there a distributor to set a tooth off.
Old Apr 16, 2004 | 08:38 PM
chy20k1's Avatar
he means the cam gear, the dots werent aligned
Old Apr 16, 2004 | 08:50 PM
97WS6SCharged's Avatar
Well technically you could install the opti with the pin in the wrong hole, and it would produce a similar effect as if you installed a normal distributor wrong. Probably screw up the opti as well.
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Feb 3, 2015 09:41 PM
Jan 23, 2015 01:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
