Timing Set Change Needed On Cam/heads Lt1?
Old Aug 18, 2003 | 10:53 PM
TexasTechTA's Avatar
This is TT TA's bro with a '94 TA that already has 1.6 RR, headers, bolt ons and the comp 503 cam specs: 224/230 503/510. Just bought a set of stage II ported heads, but haven't put them on yet. I have a the stock timing set with the stock timing chain that has 33K on it.
Do I need to upgrade the timing chain/set? I called Jegs and they said they run AFR heads and bigger cams on stokc timing sets all the time, but I'm not sure
Little help please
Old Aug 18, 2003 | 11:16 PM
Camaro_Maniac63's Avatar
You don't absolutely have to upgrade the timing chain. But if you have the means, go ahead and and get a heavy duty one while you are at it. It just gives you a little added piece of mind.
Old Aug 18, 2003 | 11:30 PM
GhostZ's Avatar
Agreed.
parkers Z28
Mar 11, 2016 08:14 PM
*Emilia*
May 13, 2015 09:05 AM
Queens94z28
Dec 20, 2014 09:11 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
