water/coolant leaking through this hose
Old 01-12-2015, 04:27 PM
94Z28LS1toLT1's Avatar
Hey guys that water hose that connects to the water pump on the drivers side below the upper radiator hose i believe its half rubber and half metal and runs all the way to the back of something lol. I see coolant/water leaking through the metal part,very slow leak. But was wondering how can i get that hose fixed, because i think it runs all the way to the oil adapter. thank u guys
94Z28LS1toLT1 is offline
Old 01-13-2015, 07:10 AM
Re: water/coolant leaking through this hose
What you are calling the oil adapter is the oil cooler. Many people delete it because they don't see a need for it (GM only installed it through 95), or because they feel it can plug up and hurt oil circulation. I've had it functional for 20+ years with no problems.
You may be able to find the coolant line from someone who deleted the cooler. Might want to try posting on "Parts Wanted".
If you delete it, you would use the "oil cooler bypass hose" shown in this diagram:
http://shbox.com/1/93-94_hoses.jpg
This is the oil cooler plumbing diagram:
http://shbox.com/1/oil_cooler.jpg
Injuneer is offline
Old 01-13-2015, 05:01 PM
my bust Fred yea the oil cooler,I couldn't remember that name to that part,checked it again and theres a small crack in the metal part of that hose.
Old 01-14-2015, 06:54 AM
As a temp fix, wrap a split piece of rubber hose around the area of the crack in the pipe, and put a band clamp over the area to hold the hose tight against the crack.
Injuneer is offline
Old 01-14-2015, 09:48 PM
Thank you buddy,but i actually got one from a guys selling parts from craigslist from a 95 LT1 and he had that part got it for 10 dollars in pretty good shape.
Old 01-15-2015, 09:22 AM
95s were different from 93-94s. So, unless you got the whole thing, it might not work.
shoebox is offline
Old 01-15-2015, 04:35 PM
Dang.... good catch. This is the 94:
Injuneer is offline
Old 01-15-2015, 07:18 PM
Hey guys my mistake I got it from a 94, i called a different guy before that asking for that hose he was parting out a 95 but didnt have that hose thank god. But did get that hose from a 94 all clear
Magenta_Hearts
03-29-2017 08:54 PM
Scorch1
06-30-2015 11:24 PM
beltrunner
04-15-2015 01:10 AM
94Z28LS1toLT1
Parts Wanted
01-21-2015 04:37 PM
pologreen97z
12-02-2014 10:42 AM
Quick Reply: water/coolant leaking through this hose
