timing set
Old Nov 13, 2008 | 01:00 PM
01pewterz's Avatar
timing set
I have an 84 Silverado with an LT1 (not sure of the year but has vented opti) and I am changing the cam to an LT4 hotcam but since I was there was going to change the timing set also. I thought since the LT4 Extreme duty set is $250+ that I might change to an electric water pump and put on a standard double roller timing set for about the same price. What I'm wondering is to those that have done this, what is a good timing set to get?
Old Nov 13, 2008 | 02:56 PM
Cloyes 9-3145.
Old Nov 13, 2008 | 03:10 PM
01pewterz's Avatar
thanks shoebox, will I have to clearance the stock timing cover for it?
And I think I read somewhere about plugging a hole in it?
Old Nov 13, 2008 | 03:33 PM
camarobird92's Avatar
What's wrong with something like the Summit SUM-G6601? Half the price of the cloyes piece. I've always had good luck with "Summit" branded parts.
Old Nov 13, 2008 | 03:37 PM
01pewterz's Avatar
sounds good to me, thats the 1 have been actually looking at, but I wasn't sure if it would work on the LT1
Old Nov 13, 2008 | 03:40 PM
bombebomb's Avatar
Summit parts can break like everything else I guess, buddy of mine had a brand new 406, ran for 30 minutes when the summit cam snapped and destroyed 90% of the engine. Something to remember, most if not all summit parts of normally made by a larger company. So if you buy a summit CAI, it might be a K&N with summt on it.
Old Nov 13, 2008 | 03:43 PM
01pewterz's Avatar
my thoughts exactly, another question i have is when I switch the waterpump to electric I guess I would just take off the waterpump gear?
Old Nov 13, 2008 | 04:13 PM
henryz28's Avatar
Yep toss out the gear. You will have to freeze plug the timming cover.
Old Nov 21, 2008 | 09:52 AM
01pewterz's Avatar
ok now after reading a few posts about the EWP and overheating, I have changed my mind (since this a truck and I will be towing and hauling), and I have been getting together parts for my heads and just figured out Lloyd Elliot is right up the road, so now my plans have changed all together.
Now my question is do I need to change my whole timing set or can I just change the chain and if so does anyone have the chain #?
thanks
Old Nov 21, 2008 | 10:44 AM
thanks
Change the whole thing.
List with GM part numbers:
1993-1997 stock crank sprocket 10128346
1993-1994 stock cam sprocket 10128349 non-vented opti
1995-1997 stock cam sprocket 10206039 vented opti
1993-1997 stock timing chain 10128485
Old Nov 21, 2008 | 01:08 PM
01pewterz's Avatar
will these parts be ok for a head/cam lt1 or should I just bite the bullet and buy the LT4 Extreme Duty set for $250?
Old Nov 21, 2008 | 03:23 PM
The stock set is used by lots of cam swappers.
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Feb 3, 2015 09:41 PM
Jan 23, 2015 01:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
