Timing Set
Old May 27, 2008 | 08:53 PM
ShownomercyZ28's Avatar
Timing Set
Where can I find a Pro gear single roller set? I can't find it on any of the big names or sponsers.....
Old May 27, 2008 | 11:07 PM
hot_red_z28's Avatar
http://www.progearweb.com/distributo...ibutor_map.htm
Not sure what your setup is, but most, including myself, just went with the LT4 heavy duty timing set...
Old May 28, 2008 | 06:38 AM
I cannot afford that as of now, and I do not plan on spinning mine any higher than 6000 so I think its overkill.
Old May 28, 2008 | 06:54 AM
2000GTP's Avatar
What kind of combo are you running? A stock replacement set might do the job as well.
Old May 28, 2008 | 09:31 AM
KyleBlue85Iroc-Z's Avatar
I got mine from Bret. Paid around $100. Do a search on here for Bret Bauer, you'll find his contact info.
Oh, and with the progear you lose the mechanical water pump, you have to go electric.
Kyle
Old May 28, 2008 | 03:22 PM
30696bird's Avatar
I got mine in yesterday from hughes in Washington Il. Their # is (309) 745-9558. I ended up getting part # PG3145T (T is for torrington bearing). It cost me $90.46 shipped ($79.95 before) Here are a few pics.......
Side view
Crappy up close pic of gears.
Old May 28, 2008 | 05:31 PM
Looks good! I sent an email to Bret, still waiting, and I am going to be running LE2 heads and an CSR ewp.
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Feb 3, 2015 09:41 PM
Jan 23, 2015 01:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
