Trick to reconnecting steering column?
Old May 27, 2008 | 12:31 PM
pcgamer4life's Avatar
Just finished getting the longtubes in, and I'm trying to get the steering column reattached to the knuckle. I noticed there's a flat spot in the column end, and a flat spot on the receiver, but it's like I just don't have the right angle to get it in there. The car is off the ground, if that matters at all... when the rain stops I'll go try it with the wheels on the ground. Is there a certain trick to it? I whacked it a few times with a hammer but didn't want to risk messing anything up...
Old May 27, 2008 | 12:34 PM
northdakota93z28's Avatar
turn your key on so you can rotate the steering wheel and then you can rotate the column with your hands and it will line right up.
Old May 27, 2008 | 12:35 PM
I did that, and I did get it lined up how it's supposed to be, but it's like they're at offeset angles and it wont go in without some force.
Jazsun's Avatar
I just popped the bottom half in while making sure the top half was lined up, once hte bottom went in I pushed the top in. Slipped right in.
Old May 27, 2008 | 12:39 PM
Was the car on the ground? Maybe it being in the air is pulling the pinion down for some reason? Shouldn't be though...
Old May 27, 2008 | 12:55 PM
SnakeOiler's Avatar
try pushing the steering linkage in (or out) so that you can line it up.
Old May 27, 2008 | 01:12 PM
Make sure you keep the steering wheel close to center. If you turn the wheel too far, you will snap the SIR coil wires. The air bag light will be on and bags no longer work.
Old May 27, 2008 | 02:05 PM
runlt1z28jake's Avatar
The coupler on mine has to be pried apart just a little every time. I just used a couple screwdrivers to pull open that slotted side about an 8th and then it will go on fine. Line up the notches and push it on till it's bottomed-out and tighten it.
Old May 27, 2008 | 03:35 PM
Still can't get it back on, guess I'm going to need a second hand to fiddle with the steering wheel to get it to line up...
Old May 27, 2008 | 03:54 PM
You have the bolt out while reinstalling it?
Old May 27, 2008 | 03:59 PM
...yes?
Old May 27, 2008 | 04:10 PM
It just won't go in, the angle won't match up between the two to make it go right in... i don't get it
Old May 27, 2008 | 04:16 PM
Well open the coupler a little more and put a small amount of antiseize or lube in the coupler. Set coupler on stud and wigggle them until they are allined. You will feel the grab. Pull down untill set like a mother or hammer lightly from top with long extension. Your wheels and steeringwheel must be almost the same position as when you did the uninstal.
Old May 27, 2008 | 04:21 PM
Did you disconect from the top? Nearest the steeringwheel?
Old May 27, 2008 | 04:27 PM
Yes, the male end of the connector is the part that attaches to the steering wheel and goes inside the firewall. I suppose I just need to get someone else to turn the wheel until I can get it to go in...
