Timing question
Old Aug 21, 2014 | 02:51 PM
USAirman93's Avatar
Timing question
Hey guys, so I just did my first cam swap and surprisingly got everything back together. My problem is when I tried to put the cam sprocket and chain back on it won't go on right. Either it will slide on to the cam dowel and not line up with the screw holes or vise versa. At a loss, tia for responses.
Old Aug 21, 2014 | 03:22 PM
Re: Timing question
Just keep trying. You'll get it.
Originally Posted by shbox.com cam install guide
Assemble chain onto the cam sprocket with the chain slack dangling below. Holding the sprocket with the dot on the bottom, lower the chain under the crank sprocket and then pull up to engage the teeth and remove the chain slack. Slip the cam sprocket onto the cam dowel. You may have to turn the cam just a little to get enough slack to get it on. After you get the the sprocket on the dowel, insert one bolt through the sprocket into the cam. Check the alignment of the dots and redo the procedure if needed.
Old Aug 21, 2014 | 03:36 PM
USAirman93's Avatar
Re: Timing question
thank you for the response sir and your instructions on your site, that's what I used to do the swap. Is it possible that I didn't put the cam at the right position? Could that cause the gear to not slide on right? If so do I have to take everything back apart to fix it?
Old Aug 21, 2014 | 10:13 PM
Re: Timing question
Just spin the cam to where it needs to be (it should easily move with no valvetrain on top of it). The pin can be at the 3 or 9 o'clock position. Of course the crank dot must be at 12 o'clock.
Old Aug 22, 2014 | 07:36 AM
raroz28's Avatar
Re: Timing question
Stick a screw driver through the cam sprocket and into the cam and gently pry up. This gives you a ton of play. I don't know of an easier way to get the chain on. Literally makes the job a piece of cake.
Old Aug 25, 2014 | 03:45 PM
USAirman93's Avatar
Re: Timing question
got it thx guys
Feffman
Oct 9, 2015 05:42 AM
sscott
Jan 17, 2015 04:30 PM
capebuf
Jan 13, 2015 07:22 PM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
