Timing question
Old Aug 18, 2008 | 04:57 PM
crazycat's Avatar
Timing question
I just had my lt1 built for boost by a engine builder. Now when he was building it he asked me about the timing on the lt1. { he hasnt built a lt1 in a while I guess. Anyway he set it dot to dot with #1 tdc. Now I looked this up and it shows #6 should be tdc. But it also says #1 and #6 are tdc at the same time. So does it matter ?
Old Aug 18, 2008 | 08:19 PM
slowride94z's Avatar
man the picture keeps changing I cant keep up, turn the motor off next time
dot to dot
it takes two turns of the crank to equal one revolution of the cam. so one turn the #1 is on top of compression, the #6 is on top of, or the end of power stroke. next round the #1 is at the end of power stroke starting exhaust stroke, the#6 is at the end of compression
I hope I got that right
Last edited by slowride94z; Aug 18, 2008 at 08:21 PM. Reason: intake compresson power exhaust not power intake lol
Old Aug 18, 2008 | 11:16 PM
MachinistOne's Avatar
Your engine builder should degree the cam to make sure it meets up with the cam card - this will eliminate questions and wasted time. Never rely on the "dot-to-dot" with any performance motor, we don't even do that on stock motors - every single one is checked on the degree wheel.
Old Aug 19, 2008 | 07:37 PM
ENRKyle20's Avatar
10 mins, a degree wheel, & a dial indicator and there is no more guess work.. I cant believe your engine builder wouldnt just do it anyway..
Old Aug 19, 2008 | 10:45 PM
crazycat's Avatar
Thanks for all the replys. For all the money I have in this build I should not have to worry about If the timing is right. I will see my builder in a few days and get it worked out.
Feffman
Oct 9, 2015 05:42 AM
sscott
Jan 17, 2015 04:30 PM
capebuf
Jan 13, 2015 07:22 PM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
