Timing pointer with stock balancer & opti
Old Jul 14, 2005 | 05:09 AM
SABLT194's Avatar
Is there an aftermarket timing pointer that will bolt on, clear the opti & wires and work out (diameter wise) with a stock balancer? I'll notch the balancer at TDC and use a timing light with an advance/retard adjustment. I just want to compare actual timing to the ECM timing tables and the Datamaster numbers.
Steve
Old Jul 14, 2005 | 06:40 AM
Tom Piper's Avatar
Re: Timing pointer with stock balancer & opti
If your hub isn't keyed, what good is a mark on the harmonic damper?
Tom Piper
Old Jul 14, 2005 | 07:33 AM
Just curious why you feel you need to verify the timing this way?
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
rocketman051894
Jan 30, 2015 03:23 PM
