Timing pointer with stock balancer & opti
Is there an aftermarket timing pointer that will bolt on, clear the opti & wires and work out (diameter wise) with a stock balancer? I'll notch the balancer at TDC and use a timing light with an advance/retard adjustment. I just want to compare actual timing to the ECM timing tables and the Datamaster numbers.
Steve
Steve
oldschool
Feb 9, 2016 09:21 PM
