Timing Issue nned help
Old Apr 19, 2007 | 07:00 AM
EvilDCustoms's Avatar
Exclamation Timing Issue nned help
so i was doing an ewp in my car and decided to change the cap and rotor, so i ordered the msd one, while taking the old one off, i took off the opti part as well thinking that back plastic piece of the cap was part of it or something, well when i took it off that center section spun on me a little bit. i reinstalled the new cap and rotor and plugged it in real quick and then tried starting the engine to make sure it worked. The car started seeemed like the timing was off and then stalled, tried starting again and won't start.
Has anyone ran into this problem before? I am a tech at chrysler so im not used to working with opti spark, how would i adjust timing on this car or would it be something else that i am missing here?
Old Apr 19, 2007 | 07:04 AM
If you took the opti completly off, you must put it back on with it oriented correctly to the dowel pin of the cam.
Old Apr 19, 2007 | 12:52 PM
that picture is the back of the opti correct? i will take a look at that later.. i hope its something that simple
Old Apr 19, 2007 | 03:44 PM
Yeah, that's the back. If you took the opti off and that picture is unfamiliar to you, then incorrect orientation is likely your problem.
Old Apr 21, 2007 | 07:10 AM
ok i pulled the opti back and reinstalled it according to that picture, it lookede to me as if it was already in the right way, i am going to try cranking it in a few hours when i go back to the shop, any easy way to know if the opti is the issue here? i have to try and have the car done today so any suggestions would be nice.
Old Apr 21, 2007 | 10:18 AM
ok tried starting it and still nothing seemed like it kinda wanted to fire but just stumbled and didn't.
Old Apr 21, 2007 | 12:46 PM
ok fixed it, found timing to be 180 off, started it up and works fine.
97Z28Muscle
Feb 6, 2015 10:44 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
Snoman73
Nov 17, 2014 07:22 PM
